Wharfedale DVDRHD400F DVD Recorder with Freeview/80Gb HDD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Irri Tant, Apr 20, 2007.
  1. Irri Tant
    Irri Tant
    Apr 20, 2007
    5
    :lease: HELP
    have the above recorder but,
    I can get sound but no picture and I want to record from my NTL box.
    Signal from cable NTL/Virgin Media box goes via scart to the Wharfedale and a scart from there to the TV (42" LG Plasma). Also have the freeview working. I can view channels on the freeview & record them.
    No matter which way round I plug in the scart's I can only get sound. Have swapped scart leads between systems but no joy. Also on 2nd Wharfedale as I thought the 1st was faulty. Argos help line is not much use either.
    :lease: HELP
  2. schnapps
    schnapps
    Feb 7, 2005
    4
    I had the same problem trying to get Sky to work through my DVD Recorder.
    If you go to the setup menu then to prferences change the AV-2 setting from Scart RGB to Scart CVBS that may work it did for me.
    I've only had the Wharfedale for a couple of days and after that little glitch was sorted I think it's a great machine although a little noisey.
    Hope this helps.
  3. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    Can you record from one channel and watch another with this, does anyone know ?
  4. planetf1
    planetf1
    Dec 12, 2002
    119
    16
    No you can't sorry. It only has a single tuner. (I picked one up yesterday - see here
  5. MuksC
    MuksC
    Aug 18, 2007
    885
    43
    +133
    that's the case with every dvd recorder with a digital tuner you can buy outside of Japan. if it has a digital tuner, it will only ever have 1 of them, meaning you can't watch a different channel to the one you're recording.
    it's not something specific just to the Wharfedale.
