Wharfedale DVD-266
Discussion in 'Video Streaming Boxes & Services' started by Baff, Jan 9, 2008.
  1. Baff
    Baff
    A couple of questions that Google has not been able to help with...
    1. The obligatory multiregion hack request!
    2. This portable DVD player has a USB slot. It says USB1 in the manual. Does anyone know if a USB TV stick (as used on laptops) will work in here? Most of the specs say they need Windows XP etc and obviously the player will not have this. If anyone has the player and a USB TV adapter already, have you tried it?
  2. DiapasonDabbler
    DiapasonDabbler
    Jul 19, 2008
    +3
    Re point 1) - no luck anywhere yet [​IMG]
    2) Pretty sure this is for picture / audio files only on a stick - i.e. it is not for other USB devices, as you have guessed. I have tried putting video on a USB stick, but it is not at all satisfactory. R u n s a b i t j e r k i l y [​IMG]
    HTH
