Wharfedale Diamond 9.sw150
Discussion in 'Subwoofers' started by scrapbook, Oct 23, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,426
    +552
    Following some recent good reviews I have this sub on my short list.
    I notice however that the crossover frequencies only range from 35 to 85hz. As the lowest crossover frequency on my amp is 100hz, I assume that I am going to miss something?
  2. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    what amp are you using? very bizarre that it won't let you crossover below 100hz...
  3. scrapbook
    scrapbook
    Jan 12, 2002
    7,426
    +552
    Pioneer 812, lets u set the crossover at 100, 150 and 200.
    Unless you can tell me otherwise, hopefully??:lease:
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Stupid crossovers on the sub as well unless it has an off option. Means you cant partner with satalite/lifestyle speakers :(
  5. scrapbook
    scrapbook
    Jan 12, 2002
    7,426
    +552
    Would setting the front speakers to 'Large' have an impact?
  6. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
  7. scrapbook
    scrapbook
    Jan 12, 2002
    7,426
    +552
    Yep, had a look at that last night. It talks about two levels, which is applicable?
    HF limit 35 - 110hz
    Crossover 35-85hz
  8. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    the HF limit is how high (in pitch) the sound will go. in this case, its 110hz (4 octaves below A above middle C on a piano if you really want to know ;)). so it'll be fine with your satellites and you won't have a 'hole' according to their figures.
    i would go for a Ruark Vita 100 from www.bkelec.com instead though. Wharfedale haven't had the best reputation for subwoofers- all the ones i've dealt with have returned due to noisy transformers and not switching to standby mode correctly.
