Wharfedale Diamond 9 center speakers
Discussion in 'Home Cinema Speakers' started by Godvrey, Aug 30, 2005.
  1. Godvrey
    Godvrey
    Hey - just wanted to ask for opinions about the wharfedale center speakers.
    I have a pair of diamond 9.1's and recently purchased a complimentary diamond 9.cs, which is their tonally matched full range center speaker. Only thing is, it's pretty big - which has been leading me to consider a possible exchange with the diamond 9.cc, which is their compact center.
    It's quite a bit smaller than the cs however - and so I was interested to hear if anyone else had experience of the 9.cc, and how they rated it. I'm getting the SW150 sub to go with it so it'll be supported by that - but still....
    I've read in another forum that it's a bit weak - but view here would be much appreciated.
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Tty allways to get the center from the same brand, series, and with same drivers, including woofer diameter if possible... then...
  3. Godvrey
    Godvrey
    In that case I guess it will be the larger of the two - the diamond 9.cs which I have now. The compact center has smaller drivers - although it is the same range and make
  4. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Well... go and have a listen...
  5. Godvrey
    Godvrey
    Well, like I said - I already have it. It sounds good - question was the size. Time is running out for an exchange however, and I don't really have time to go listen to the smaller one.
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Have a listen to the smaller one...
    I would stick to the right one...
