wharfedale diamond 8 screen 3
Discussion in 'Home Cinema Speakers' started by thelordmagus, Apr 20, 2005.
  1. thelordmagus
    thelordmagus
    Dec 11, 2004
    138
    Paris
  2. Helicon
    Helicon
    Apr 4, 2005
    5,005
    +261
    Personally, i'd steer clear of Wharfedale. They're neither an AV speaker, nor a hi-fi speaker. The 8's are cheaply made, use cheap drive units, and don't sound any better than ok. There's so much choice at this level that almost anything will be better. Just being honest.
  3. CosmosD
    CosmosD
    Oct 28, 2004
    163
    Dover
    +7
    Been using the same package for nearly 3 years now and IMO the reviews they received were well deserved. Maybe not in the class of Helicon's M&K speakers but for £230 I think they may be hard to beat. One point to consider is that only the centre speaker is shielded so don't put them to close to a CRT screen i.e. <0.4M
  4. Helicon
    Helicon
    Apr 4, 2005
    5,005
    +261
    Just to point out i'm not comparing them to my M&K's, very little will, but i used to manage a store that sold them and i know what they're like. If you want a lot of speaker for your money, fair enough, but even Missions sound better than these, not that they are any better made.
  5. thelordmagus
    thelordmagus
    Dec 11, 2004
    138
    Paris
    okok, thanks for your replies. I should have explained something here: I am short on budget, and my living room is not huge. I have spent about the same budget on the receiver and the DVD player, which means that I don't really see the need of spending hundreds of pounds on speakers alone, that would make a strange combination :nono:
    I personally don't like the diamond 8 series visually in maple (really really horrible looking) but in black they're quit descent.
    And thanks for the shielding info. I will have a good 1.5 meters to each side, so it should be more than ok.
    LM
  6. CosmosD
    CosmosD
    Oct 28, 2004
    163
    Dover
    +7
    For the money, I still think they are hard to beat and they received great reviews when released. Probably a good match to your systems budget. You won't be disappointed TLM.
  7. thelordmagus
    thelordmagus
    Dec 11, 2004
    138
    Paris
    Sorry for the late reply, was stuck at home with a bad back... yeah I ordered them last Saturday at hifibitz. They are not in stock but they said they could get them fairly quickly from Wharfedale... I hope they're right ;)
