Wharfedale 8.2 upgrade
Discussion in 'Home Cinema Speakers' started by janm399, Jul 7, 2005.
  1. janm399
    janm399
    I have a pair of Wharfdale 8.2 speakers with an entry-level AV Amp (Sony STDRB795) and I am looking to slowly upgrade to a full 5.1 speaker set, starting with the fronts and centre speakers.
    I have about £400 to spend; is it worth getting rid of the Wharfedales and if so, what fronts & centre would be the best in terms of sound and value for money?
    Thanks,
    Jan
  2. thekingbeyond
    thekingbeyond
    May 24, 2004
    5,444
    oxfordshire
    +334
    keep your existing wharfedales for rear duties and partner them with Wharfedale Diamond 9.CC Centre Speaker £100 or the more expensive Wharfedale Diamond 9.CS Centre Speaker £149.95 and the Wharfedale Diamond 9.1 Loudspeakers £180 for your fronts, this would leave you some cash to go towards a sub
    Have you seen the wharfedale 5.1 package for £100 over you budget
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/2210
