Wharfedale 17 Inch Freeview Query
cedric
Established Member
Hello peeps
I am looking at buying the much discussed Freeview Wharfedale 17" LCD with Freeview but I would be using only a portable Aerial In the bedroom
Does the tv have an analogue tuner also or will it only show the freeview channels ? I am going to sort out a digital aerial shortly but until then need to now if the tv would be unwatchable --I am in a poor reception area
Also would I be able to merely buy one of the cheapie 20quid digital aerials and just hook it up in the bedroom?
If the answer is no analogue I am knackered unless I get a digi aerial installed in the loft ---- I will have to do it earlier than planned!!
Any advice would be appreciated
russ123
Established Member
I've one of these and it definitely has an analogue tuner in it as well. The picuture is not as good though (as you'd hope for:) ). Initially I got it working with an indoor aerial with reasonable results. I am only about 6 miles from the mast at Crystal Palace though so I imagine I'm classified as a strong signal area.
cedric
Established Member
Excellent news Russ
Not been able to find out if it has an analogue too
My picture will probably be crap but at least I will have something until I get a digital aerial fitted:thumbsup:
LG G3 MLA OLED Evo Best Picture Settings - works for ALL 2023 LG OLEDs
Back
