creddish
Established Member
You can download a PDF of a Manual from the Sharp site here. Follow the "Operation Manuals" link, select TUR160HA from the drop-down list, select Search. From the options given download the file called "TUR160HA Revised Operation Manual - Only applicable to units produced after Oct 2007". This is not a manual for your particular unit but it will be suitable for most functions.I got one of these, and apart from the overly complicated remote control (too many buttons that seem to mean the same thing)it works OK, except.........
Every now and then it seems that is loses all the tuned stations and I just get a green screen. Now I have lost the instruction manual and can't remember how to re-tune from scratch.
Help - anyone got an instruction manual they want to flog???
I have had very occasional "green" screen on my Vestel PVRs but I don't believe it is a common bug. You can check the signal strength and quality of each of the signals from the 6 Freeview MUXs using the MANUAL CHANNEL SCAN facility. If you know the UHF channel numbers for your transmitter enter these in-turn in the box on the screen and read the data presented. If you don't know your channel numbers just scan through the range of numbers from 22 to 66 until you find the appropriate ones. Alternatively you can the data from the site here.
Colin
