Wharfdale Diamond 7.1 as rears?
Discussion in 'Home Cinema Speakers' started by theo cupier, Dec 27, 2004.
  1. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    just found a pair of these tucked away in my loft, which I'd completely forgotten about!
    should I consider myself lucky and use them as rear l & r for the surround system I'm about to get (to work with my rogers LS4a fronts) or should I consign them to landfil and get something new for this job?
    Probably going to get a Marantz SR5400 or Yamaha DSPE800 processor (fronts will be driven by Musical fidelity B1, via the processor's pre-outs. B1 will also continue to serve direct for audio-only sources.)
    Would anyone care to comment on suitability of the Wharfdale as shelf mounted rears?
    Also, your recommendations for a centre speaker to compliment the LS4a are invited. Budget is not huge (no more than £250 max)
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,517
    London
    +1,005
    You could use them as it will save you money, but I always prefer to match the speakers from the same manufacturer and range if possible. Why not hook them up and see how they sound, if they're not good there's always eBay :D
  3. MikeRJ
    MikeRJ
    Oct 21, 2004
    226
    Plymouth
    The 7.1 were great little speakers for the money, I still have a pair of the active 7.1's on my PC. Should be perfectly adequate for rear channel useage.
