Wharfdale 750s
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kulashaker, Nov 25, 2000.
  1. Kulashaker
    Kulashaker
    I've just bought one of these machines and can't for the life of me get ANY of the reported hacks to work. Can anyone shed some light my way before it goes back to Tescos. Mail me at
    kulashaker0@yahoo.co.uk
    Regards, KulaShaker.
  2. Guest
    could you email me with the asnswer too please stephenjohn.downs@ntlworld.com
    [This message has been edited by stephen64 (edited 08-12-2000).]
  3. DarrenMurphy
    DarrenMurphy
    If anyone has got this working can you please mail me as well
    cheers
    dmurphy@energis-eis.co.uk
  4. DarrenMurphy
    DarrenMurphy
    Try this it works for me and I have a 750s with a new style remote let me know how you get on
    There have been a number of reports that the Wharfedale DVD750s region hack may not work on all DVD750s players.
    you need to have the tray open and a disc in after you put in the crack close drawer and should be OK
    Try This ..
    1 Press 'Step'
    2 Press 'Prev'
    3 Press 'Next'
    This should set the player to multi-region.
    If you need to go back to Region 2
    1 Press 'Slow'
    2 Press 'Prev'
    3 Press 'Next'
    [This message has been edited by DarrenMurphy (edited 08-12-2000).]
  5. clone
    clone
  6. graeme
    graeme
    This hack also works for me too. There are 2 generations of the 750s, and are as follows
    De-regionalising a First Generation Wharfedale DVD750S can be done in one of two ways. The first removes all region restrictions, the second allows the user to specify a particular region.
    Hack 1
    · Open the drawer
    · Press ZOOM
    · Press A->B
    · Press the UP CURSOR
    · Press the LEFT CURSOR
    · Press the DOWN CURSOR
    · Press the RIGHT CURSOR
    Hack 2
    · Open the drawer
    · Press 1 four times
    · Press the number corresponding to the Region you wish to set the player to
    The Second Generation Wharfedale DVD750S has a different hack for both Multi-Region and specific region playback. Multi-Region playback is enabled as follows:
    · Press Step
    · Press Previous
    · Press Next
    To set a Second Generation Wharfedale DVD750S back to Region 2, enter the following:
    · Press Slow
    · Press Previous
    · Press Next
    Finally, to set the Second Generation Wharfedale DVD750S to a specific region, enter the following:
    · Press 0, 7, 5, 0
  7. bradavon
    bradavon
  8. Stamford
    Stamford
    Apr 14, 2002
    7
    All i do on mine is open the drawer, press number 1 four times followed by which ever region number it is!
  9. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Kulashaker, you didn't seriously like Kulashaker (the band) did you?
    Go....vinda di-ah di-ah Go...vinda di-ah di-ah :D ;).
