**WH36 Convergence Issue???
Discussion in 'General TV Discussions Forum' started by Dts007, Nov 5, 2003.
  1. Dts007
    Dts007
    Dec 11, 2002
    131
    +5
    Ok, I have the 57" set. Got it very very recently. Noticed a problem where the bottom right hand side is slightly tilted upwards, all other areas are OK. Eg, when you are viewing SKY and start to switch channels the small bar that appears at the bottom is tilted upwards on the right side.
    Yesterday I decided to check convergence in the service menu & found that all the colours perfectly match the white grid however the white grid itself isn't straight in the bottom right hand side - It is tilted upwards slightly. All other areas are straight.
    How do I fix this? Help! Its driving me NUTS!.
    Thanx in advance.
    DTS007
