WF 100 compression fittings info
Discussion in 'Satellite TV, Sky TV & FreeSat' started by thorley37, Feb 6, 2014.
  1. thorley37
    thorley37
    Apr 19, 2006
    895
    +23
    I thinking of buying a reel of cable to redo my TVs and satellites, is this cable RG6 or RG59 so I buy right fittings
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,170
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,071
    Poole
    +10,929
    WF100 as per Kev's link.
  4. thorley37
    thorley37
    Apr 19, 2006
    895
    +23
    RG6 it is then, thanks for the info
  5. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,657
    Cheshire
    +1,082
    It's not just that it's RG6 - it can still vary dramatically in quality from brand to brand, some cheaper coax can be a smaller overall diameter &/or the plastic outer & dielectric can be soft & capable of crushing resulting in a poor fitting or over time.
    Webro WF100 is relatively expensive but it's not only a well respected & approved coax, good quality self seal compression fittings will seal on WF100 to their specification where they may not on cheap coax.
    There's also Triax TX100 as an easy recommendation - they are similar in quality & price- the main difference is the copper in WF100 is near pure copper & tx100 uses higher tensile copper alloy but the additive adds much more strength & only about 6% to the attenuation figure so there are applications where one would look to using the stronger coax where that small added attenuation is a reasonable trade off eg the relatively strong signal wise sky/ virgin & most irs's etc.
  6. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,071
    Poole
    +10,929
    Agreed, for example CCS (copper Coated Steel) is OK for a few connections but that's about all.
  7. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    The problem with steel wire is that it has a high resistance. The copper coating reduces this for high frequencies but the steel still has to carry any DC current. So, for applications where it has to carry current to (say) an LNB, you must calculate carefully the voltage drop in the cable because even 1 volt drop could be enough to prevent the LNB from switching to horizontal polarisation.
  8. thorley37
    thorley37
    Apr 19, 2006
    895
    +23
    these are the fittings I am going to buy "PPC EX6NTPLUS/RG6 COMPRESSION F CONNECTORS",anyone have a opinion on them
  9. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Why the insistence on RG6? Are you in America? RG6 alone does not define the cable type. In the UK anything listed as "RG6" is probably best avoided if you need it to carry current.
  10. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,071
    Poole
    +10,929
    Hence people saying WF100.
    RG6 defines (if I remember correctly) the dimensions and impedance only.
  11. thorley37
    thorley37
    Apr 19, 2006
    895
    +23
    will these fittings be OK, if not what would you reccommend
