West Somerset : I need someone to connect up my tv to video to sat to dvd. Help.
Discussion in 'General TV Discussions Forum' started by Paul Howles, Feb 8, 2002.
  1. Paul Howles
    Paul Howles
    I live in Minehead, and I need someone to set up my av system for me. Payment is not a problem. Is there anyone out there who can help?:(
  2. Doubledoom
    Doubledoom
    Dont pay anyone to do it. Just follow the instructions below and ask any questions.
    Various ways to connect depending on what you think is acceptable.
    option 1 - RGB for both DVD and digibox but need to record via the RF.
    Audio carried from TV to Amp and DVD to amp (TV passes audio from vcr and
    digibox)
    DVD > Digibox VCR scart ( use scart lead, set DVD to output RGB)
    Digibox > TV (use scart lead into RGB scart socket)
    Video > TV (scart lead into composite scart socket - Don't use an expensive cable, it would be wasted)
    Aerial > digibox > vcr > TV
    DVD > Amp (using digital co-ax or optical -identical quality, depends on your available connections)
    TV > Amp (using 2x phono connection)
    Option 2 - RGB for digibox and s-video for DVD. Allows recording via the scart. Audio the same as above
    DVD > TV (scart into s-video scart)
    Digibox > TV (scart into RGB scart)
    Digibox > VCR (composite scart - Don't use expensive cable for this one)
    Option 3 - TV doesn't pass audio or doesn't pass it with decent quality. Will require manual switching between sources. Use video connections as option 1 or 2.
    VCR > Amp (using 2x phono connection)
    Digibox > Amp (using 2x phono connection)
  3. Paul Howles
    Paul Howles
    Thanks Doubledoom for your suggestions. I will try them once I can get my girlfriend away from the soaps. Cheers.
