SilentSniper
Established Member
Hi All,
As the title says I thought the Samsung UE75TU7020 represented great value at £799 for a 75".
Unfortunately, I think because it is a tn panel, it doesn't have very good blacks, isn't very bright and gets washed out easily.
I therefore want to send it back and spend a bit more to get something better.
Is the q60 an ips panel and would it improve visually? I know the q80 and q90 are much better but are almost LG CX oled money, but what represents the best bang for buck with decent performance?
Hoping for something in the £1200 range but can be flexible.
Use is 50% 4k gaming (ps5 and pc 3080) and 50% movies.
