Well you can only wait so long
Discussion in 'Home Cinema Buying & Building' started by Lanski14, Dec 24, 2006.
  1. Lanski14
    Lanski14
    After getting square eyes on the net I've finally decided enough was enough have now ordered my 507 with Denon 2307 and 1930 with B&W M1s and a velodyne sub (after a great demo). Having finished patting myself on the back, my ignorance around interconnects has`started to dawn on me. While the retailer has been helpful, I think hes confusing me with someone who understands what he is saying.
    My plan is to run everything through the amp with just one HDMI to the screen (4m away). I want to keep cabling between screen and amp to a minimum as it will need burying in the wall.
    What I still cant get my head round is a decent plan for the interconnects for the rest of the kit.
    I understand that the connection between DVD and amp should be Optical or digital co-axil, but which is best and why not HDMI.
    Then what about the Sky+ box. Is it best to use HDMI. If not then what.
    The retailer said I need a RGB /component (£90) but for what I'm still not clear. Any ideas or advice please.
    The only other thing I want to ensure is in due course I can attach a decent game console. Whats the best connection for this. Equally, to play some of the old family vidoes ( while i done intend putting a video in the cabinet)as and when we want to watch one is it best to simple use a scart between the video and amp.
    Sorry for blathering on but I cant help it and probably wont be able to shut up till I understand this.
    Seasons Regards.
    Lanski.:lease:
  2. jezzer256
    jezzer256
    Oct 18, 2006
    1,879
    63
    Sussex
    +164
    I can't help on much of this, but when I bought my 2307 I was told it can supposedly upconvert composite to HDMI. Therefore, if you run a scart-composite lead into the amp from your VCR, you won't need another cable through the wall :thumbsup: .
    Oh, and if it helps, the general order of quality for video connections is composite, s-video, component, HDMI (DVI). Well this is what I understand anyway - I have missed out several because I'm not sure where they fit in :).
    Have a good Christmas :smashin:.
    Jez
    EDIT: I doubt the sky+ box has HDMI out, but if it does then use that. If not, use component. The best connection for a games console would be component, however with the Xbox 360 I am not so sure. The PS2, Xbox, gamecube etc will probably only have composite out - I am not really familiar with consoles as I tend to do all my gaming on computers :). As a general rule of thumb, stick to the order I said above where possible :smashin:.
