Well, pio 5100 or panny E100?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sparkybun, Oct 12, 2003.
  1. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    Hi all,
    Sorry to ask the question BUT Pioneer 5100 or Panny E100 (or the HS2 come to that!). I know the 5100 hasn't got RGB in but is the difference in picture quality that noticeable? Is -RW worse or better than RAM. All opinions greatly accepted (especially from RASCZAK!!).
    Mel
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    When choosing between the Pioneer 5100 or the Panasonic HS2/E100 then you should ask yourself "Do I want RGB in?". This is only a question you can answer. Opinion is on the subject is, predictably, split. Whilst RGB should always give the better picture, poorer sources can (by some accounts) look better in S-Video. I don't believe this - in recent years I've had various CRTs, Plasmas and one Projector has always resulted in RGB sources (even from 'poor' sources like Sky) have always look superior. However a large number of people DO say that the S-Video looks 'better'. As 'better' is subjective I'd say wire up your TV to a number of sources - S-Video and RGB and judge for yourself.
    Anyway if your answer to the "Do I Want RGB in" question is NO then I would pick the Pioneer 5100 - simply on the fact that DVD-RW is alot more compatible than DVD-RAM. UNLESS any of the E100 factors are of interest.
    If your answer to the "Do I Want RGB in" question is YES then you need to choose between the HS2 and E100. By default I would go with the HS2 (as it is £200 cheaper!). However if any of the following are factors then choose the E100:
    - Price is not an issue.
    - MPEG4 recording will be/may be useful to you (digital camera owners, owners of Panasonic media devices)
    - You want picture thumbnails on your DVD-R menus
    - You want DVD-Audio playback
    - You want high speed dubbing to DVD-R
    - You want a larger HDD (bearing in mind the HS2 can take a full 7hrs at top quality - the E100 can take twice as much).
    Bottom line: The E100 and 5100 are similar machines - you won't be disappointed with either.
  3. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    Rasczak,
    Thank you for that. Would you say that the -RW editing features on the 5100 are as good as the -RAM on the Panny machines. I have a DV camcorder and would be using this feature (I also have a Panny DVD writer on my PC but I find this is very time consuming!!).
    THanks
    Mel
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    They are virtually identical. It's all rather irrelevant though - with a HDD/DVDR combo you'll find you do all initial recording and editting on the HDD (where the two types of machine ARE identical) - you'll just dub your recorded (and editted) material to DVDR.
    As I say apart from the RGB issue and the compatibility of DVD-RW versus DVD-RAM there isn't much between the machines.
  5. sparkybun
    sparkybun
    Jan 6, 2002
    1,195
    41
    EN8 area
    +23
    Thanks for your input, Racszak.
    Does anyone know the cheapest place for a 5100. I've found Empire at £611.
    Thanks in advance
    Mel
  6. PhilipL
    PhilipL
    Jan 18, 2002
    3,833
    103
    +439
    That is the about the cheapest I have seen, although they have none yet.
    Regards
    Philip
