Weird upmixing (?) issue with NR906
CrazyCat
I've got an HTPC hooked up to my Onkyo and it's been working fine for ages - but recently, i've noticed that when I play DTS-HD MA 5.1 material, the display shows "ES-Matrix" as opposed to "DTS HD Master".
If I play DTS-HD MA 7.1 material, it shows up normally, as above.
I swear it never used to do this, and I've not changed any settings on my players or codecs (I was assuming I had set some kind of option to upmix 5.1 to 7.1).
I've checked the listening mode presets in the setup and nothing there has changed either :confused:
Anyway, it's the first time i've ever seen "ES-Matrix" on my Onkyo and I want it back to how it was before! :D
Any help really appreciated!
leo79
I have the same problem with my 905, although mine displays dolby digital not matrix.
Double check that dts-hdma is set correctly on amps settings.
I find the only solution is to turn off amp and media player, disconnect power leads and leave for a minute.
Plug everything back in and switch on, sorts it every time for me.
cheers
leo
