Weird Tosh problem???
Discussion in 'Televisions' started by ldoodle, May 3, 2003.
  1. ldoodle
    ldoodle
    Can anyone with a 32/36ZD26P check if when they press the menu button, or change the volume, that the screen kind of streches in the corners.
    Having just checked it, it seems it does it with bright areas. The in-game menu on Animal Crossing causes this, and the fire in Splinter Cell causes it to go in and out rapidly (as if the edges are swaying in and out)
    Any ideas?
    Thanks/...
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Power supply is probably marginal, slight extra drain in resources when you increase volume etc means insuffivcient power to keep the picture stable.
    Bit like when you start up the washer the lights dim momentarily until the power supply catches up with the demand required.
