weird sounds in aliens end credit......
Discussion in 'Movie Forum' started by gargoyle, Jun 19, 2003.
  1. gargoyle
    gargoyle
    Nov 8, 2000
    629
    birmingham
    +21
    All the different formats carrying 'Aliens' appear to have one thing in common - right at the end of the credits as the last line scrolls past, you hear this strange 'creepy' crackling sound - just like an egg opening!
    The first time I heard it (when I had assembled my first home cinema kit in the eighties), it really freaked me out and since then, having purchased the vhs, several ntsc LD's, and one dvd have found the sound is still there - is this intentional (someone has suggested that it is the sound of an egg opening whilst ripley and hicks are in cryo leading to the events of alien 3) or is it just a glitch?
  2. nathan_silly
    nathan_silly
    Watch Alien 3. It should give you the idea why they had the facerhugger scutter.
  3. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    I have not noticed these sound effects before. I don't usually watch all the credits.
    It would add something to the continuity of the films. I wonder if James Cameron intended to make Alien3.
    Look like something i'll have to check out.
  4. Adam Barratt
    Adam Barratt
    Aug 9, 2000
    170
    16
    New Zealand
    Listen in plain stereo (make sure the volume is up quite high) and you can hear a facehugger running across the room in front of you, from left to right, right at the end of the credits.
    Adam
