Weird Sim2 HT300 Link Problem
Discussion in 'Projectors, Screens & Video Processors' started by VUDSM, Jul 1, 2005.
  1. VUDSM
    VUDSM
    To Jeff or Alan (or anyone else),
    I have a Sim2 HT300 Link (not the E Version) and a Pioneer S969AVi DVD player (same as the 59AVi and the 868AVi). I have been running this for 18 months without any problems until last night. The Pioneer is set to display "1280x720P" and is connected to the Sim2 via HDMI. The Sim2 is in "Pixel to Pixel" mode. Last night the PJ would not display a PAL DVD (ie no picture). I then tried an NTSC DVD and everything worked. I turned off the PJ (including the DOIP) and the DVD player and tried again. Once again, everything is fine for an NTSC DVD, but no picture for any PAL DVD. If I change the output resolution of the Pioneer to "1920x1080i", everything works for both PAL and NTSC DVD's. To check that the DVD player was not at fault, I connected it to my Pioneer PDP-505HDG Plasma at "1280x720P" and everything worked fine.
    This is really strange as up until last night, everything was working great. I have not made any changes to the DVD player or the PJ.
    Have you ever come across this problem?
    Would re-installing my firmware (2.37.04(L)) be of any use?
    One other thing, I have a PAL HDTV box hooked up via DVI to the PJ. I checked the "1280x720P" mode and the PJ displayed this without any problem.
    Any thoughts or help would be much appreciated.
    Derek
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Hi Derek
    I have replied to your other thread and I suggest you try the latest s/w ( 2.45.04 ) to see if that resolves your issue.
    Regards
    Jeff
  3. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Hi Derek,
    s/w is on its way.
    Jeff
