??? weird question ???
Discussion in 'Blu-ray & DVD Players & Recorders' started by weezz, Sep 23, 2005.
  1. weezz
    weezz
    Aug 24, 2005
    29
    I have a weird question about dvd players
    If i was to buy a SACD player, will my movies sound better on a SACD, rather than a regular dvd player???
    I know the purpose for a SACD player is to mainly play super audio disc
    I wanna buy one but i need some input on it???
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    Not quite sure what you are asking here?
    If you are asking , will DVDs sound better than on a DVD player capable of playing SACDs vs one that isn't, the answer it no. The fact that a DVD player can play SACDs has no bearing on DVD performance.
    If you are asking will DVDs sound better on a dedicated SACD player, the answer is no because DVDs won't play on a dedicated SACD player - as you say they are designed for audio SACDs only...PJ :)
  3. weezz
    weezz
    Aug 24, 2005
    29
    thx for the reply PJTX100
    then it seems like theres no need to buy it
