Weird problem with Sky+ through my AMP
Discussion in 'Sky Digital TV Forum' started by BlueNose66, Nov 6, 2005.
  1. BlueNose66
    BlueNose66
    May 28, 2005
    52
    Went to watch a film last night on Sky Movies 1, this was through the amp (Denon 1906), the problem is I am getting no sound, this is the same for Sky Movies 2 and 3, but all the other channels are working fine. If I then turn the sound up on the plasma, sound comes through the speakers, also tested on other TV's in the house and they are also working fine. :suicide:
    Last week I watched a film on Sky Movies 1 through the amp and this worked fine, is it something to do with the upgrade and sound signals.
  2. thanley
    thanley
    Sep 11, 2002
    225
    28
    Orpington
    +30
    Go in to the sky+ audio settings and make sure that the audio is set to digital. to confirm the presence of a digital signal, have a look at the back of the box, you should see a red light emitting from the optical out socket.
  3. BlueNose66
    BlueNose66
    May 28, 2005
    52
    The settings are set to Stereo and Dolby for sound, there isn't a digital item on there, but why would all the other channels work with the exception of these three?
    I'm confused :suicide:
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    the dolby setting is digital....how are you connected to your amp?
  5. Hairy Herman
    Hairy Herman
    movies one, two and three are the only channels (apart from disney sometimes) that use dolby digital as opposed to PCM stereo
  6. BlueNose66
    BlueNose66
    May 28, 2005
    52
    Optical Cable :thumbsup:
  7. BlueNose66
    BlueNose66
    May 28, 2005
    52
    Watched a film last week on it without any problems and it changed to Dolby when the film started. :thumbsup:
  8. BlueNose66
    BlueNose66
    May 28, 2005
    52
    Just had a thought and on the remote changed to Auto, it then picked up the sound on Sky Movies 1. :clap:
    Phew.
    Cheers for the suggestions folks. :thumbsup: :thumbsup: :thumbsup:
  9. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    the sound on those three channels is sometimes lower than on others, depending on your amp, but so long as you are connected by optical and have sky sound set to dolby I can't think what else would cause the loss of sound. (assume you haven't changed settings on your amp?)
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    doh! :)
  11. BlueNose66
    BlueNose66
    May 28, 2005
    52
    :D :smashin:
