Weird keyboard issue - replace?
Discussion in 'Desktop & Laptop Computers Forum' started by Crafty, Aug 28, 2018.
Tags:
  1. Crafty
    Crafty
    Jan 28, 2004
    1,389
    113
    +706
    I have a Dell 15R laptop which is about 6 or so years old. Generally its fine but recently the keyboard randomly plays up - usually the top row of letters stops working, most of the time if I just keeping tapping the key I want it eventually works and then is perfectly fine. Sometimes its only half of that row.
    Tonight the bottom line of letters are playing up - keys only maybe 25% of the time on first press, sometimes takes 10 presses to make it work, other times it works second press. Until ow its only ever been the top row.
    USB keyboard works fine, on-screen keyboard works fine, various malware scanners find nothing (I'm thinking keyloggers etc)
    I can get a replacement keyboard for about £15, it can't e much else other than failure of the keyboard itself can it ?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,940
    Norfolk
    +2,549
    It could be something like the keyboard connector on the motherboard so it's not guaranteed, but it's likely. If you're otherwise happy with the laptop then it's worth a go.
  3. Darren Heal
    Darren Heal
    Jan 23, 2013
    192
    Northwest Houston TX
    +8
    Try a little blast if compressed air from a can. It could be accumulated crud under the keys.
    You could try vacuuming but you're just as likely to loose half the keys (don't ask how I know.
    If the keyboard does need replacing you can find knock off and or genuine ones on Fleabay for not too much money and either replace it yourself or get your local repair Shoppe to do it for you.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,600
    Rainham Essex
    +2,543
    A lot of laptops use a compression connection for the keyboard. I've know these to get loose over time, or even just dirt work its way in. So it could be just a simple remove the connection and remake it to get a fully working keyboard.
    Mark.
  5. Crafty
    Crafty
    Jan 28, 2004
    1,389
    113
    +706
    Thanks guys, I will try reseating the connector
