When I try to set my second monitor to its native resolution (1360*768) this happens:
I can select the resolution when the monitor is disabled but when I enable it that specific option disappears.
The card is an Nvidia 8600 GT
Also I don't get this problem if the second monitor is the only monitor being used.
I can create a custom resolution and select 1360*768 but this simply resets itself after a reboot so I can no longer select it until I delete and the re-add the custom resolution.
