Weird issue with Toshiba SD900
Discussion in 'Blu-ray & DVD Players & Recorders' started by DEO, Oct 11, 2003.
  1. DEO
    DEO
    Hi, suddenly at 9pm today DVDs started playing with no sound!
    Very frustrasting. It is set to bitstream in the audio out menu.
    Does anybody have a suggestion?
    Dave
  2. Jase
    Jase
    Mar 16, 2001
    9,469
    South Coast
    +893
    Obvious one would be check the cabling. Try another cable just in case. If you're using a coaxial cable try an optical one to see if that works.
    Doublecheck the amp as well, set to the correct input, assigned correctly etc etc.
