I hope this is the right forum for this Q.
Is it possible for an ethernet cable to "die" (fail) and if so how does one test for this?
Background:
1. My set up is router -> 24 port switch -> wired connections around the house plus wireless connections off various APs.
2. One of the wired connections off the switch runs to an outbuilding. Max 50m cable run (I ran the original cable run from a 50m roll and had spare).
3. The first half or so of this cable run, which is newer, is exterior use grade cat 5 cable. That's been there for maybe six years. The second half is internal use grade cable, run inside trunking. That's been there for 8 years.
4. In the outbuilding is a wifi AP, with wired connections to back up NAS drives, Sonos, Apple TV etc. The backup NAS drives make this an important connection.
5. Recently the outbuilding has been suffering from slightly slower connections and increasing Sonos drop outs. There's been no physical activity around any part of the cable during this time. Now though - as of yesterday - the outbuilding is to all intents and purposes dead. By which I mean (a) the AP shows up as an attached device on the router's attached devices page, with its designated IP address, and broadcasts a wi-fi signal. But it carries no data - you can't access the web via its wifi signal, and if you ping it from the house at least one, usually 2 and sometimes three of the four packets of data sent are lost. (b) I've tried two different APs to rule out AP failure. No difference. (c) I've tried a different port on the switch to rule out a switch issue. No difference. (d) I powered down everything in the house and did a complete cold restart. First up was the router, then the switch, then the outbuilding AP, and nothing else. Even then the AP was doing nothing, so it's not a traffic issue.
7. The only thing left I can see as the source of the issue is the cable. Next step will be to open up the junction box. If that is dry, that suggests either a break in the cable somewhere, or perhaps a failed plug / socket somewhere in the outbuilding.
Anyone have any ideas on what might be a cause here? I am running out of options.
TIA.
Background:
TIA.
