Webcams
Discussion in 'Photography Forums' started by mikeinsthelens, Aug 30, 2004.
  1. mikeinsthelens
    mikeinsthelens
    Not sure if this is covered under this Forum.
    Can anyone recommend a decent webcam??
    I will be using it to contact family abroad and would require a fairly good one. I have seen some where the screen only refreshes every few seconds I need a fairly quick one.
    Any help appreciated!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,470
    Rainham Essex
    +2,479
    You may well already have a very high quality web cam!
    Many of the newer digital camcorders can be connected to a PC via USB and used as a web cam, and you wont get better quality than that. Software is normally supplied with the cam for this, but if not search this site for details of useing a camcorder as a web cam as it has been covered a few times in the past.
    If you don't have a camcorder then many digital stills cameras can also connect to a PC via USB and can output video, not as good as a camcorder but should be better than many web cams.
    Mark.
