Weak digital signal....
Discussion in 'Freeview & YouView' started by Takwa, Feb 10, 2009.
  1. Takwa
    Takwa
    Feb 8, 2009
    15
    3
    My area for freeview is really weak and add on to that I have only got an indoor aerial, is there a way to boost the signal?
  2. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    You could try indoor boosters etc. but, by the sounds of things, you'd be wasting your time and money.
    A weak signal area is just that and requires the best possible aerial installation for reliable reception.
    Things, hopefully, will improve when the digital switchover is complete.
    Read here
    http://www.avforums.com/forums/freeview/826100-freeview-f-q-s.html
    and enter your postcode here and post the results
    UK digital TV reception predictor
  3. Takwa
    Takwa
    Feb 8, 2009
    15
    3
    I really don't know if it's really weak, I live in zone 2 south london. I checked and the date of change over is 2012!!!!!!
    Do you recommend any booster, as it's only a few channels that are a bit weak, most are ok with a normal aerial.
  4. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    If by "Zone 2" you refer to transport zones it could hardly be less useful information for this purpose as you could be next to C Pal or far away in rustic Putney and behind a hill/buildings. Also, many of our wise members come from places like Yorkshire so know no more of Zone 2 than you do of Ilkley Moor. :D
    The wolfbane info - see Fernandez post - is useful.
    I don't think we have collective wisdom on cheap amps relative performance. So try any.
