we need an interesting thread to inspire!
Discussion in 'Projectors, Screens & Video Processors' started by NickBull, Dec 7, 2001.
Thread Status:
Not open for further replies.
  1. NickBull
    NickBull
    Things are getting a bit static, what we need is an interesting thread to inspire lots of responses.
    Unfortunately I'm not the man to provide it!
  2. uncle eric
    uncle eric
    Nic,
    You know I'm the King of interesting threads :rolleyes: , dont worry, I have one in mind for the PJ section soon.
    Eric
  3. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    i have a sanyo plv30 connected to a denon dvd2800
    the other evening i was watching cats and dogs region one in progressive scan and three quaters of the way through the film
    my projector lost sinc with dvd player i got a blue screen for about 2 seconds then my picture reappeared and it was in 4.3 and i had to change it back to widescreen......
    any ideas
    thanks jason
    :confused:
  4. MaJong
    MaJong
    radio hams near by?
  5. NickBull
    NickBull
    That's an odd one. Has it happened again?
    It might be worth starting a new thread, might get missed on here!
    Nick
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    This is a known glitch that can happen with some fixed pixel devices, not just PLV30, when fed a signal from a progressive scan device, be it Iscan or prog scan DVD player....
    The blue screen is caused by the projector loosing sync with the incoming signal. This usually happens on bright flashes of light. Play the same part of the film again and you should be able to repeat the phenomenom. Silicon Image modded the Iscan to stop this happening with PLV30's and I think SIM2 changed the operating software in HT200/DM to fix it as well.
    Gordon
  7. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    thanks for the info gordon !!!
    what do you recommend i do ?
    every time i watch a film with bright i dont want to lose my picture!!!!
    i dont want a progressive dvd player that i cant use properly because manufacturers wont get their acts together and make everything compatible.....
    jason
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    I would speak to the dealer you got the DVD2800 from and ask them to get in touch with Hayden Labs (DENON distributor) to see if there's any mod that can be done to the progressive output of the dvd player to stop it happening. There's a lot of Silicon Image bits inside the DVD2800 so it may be that whatever is done to an Iscan may be compatible with the DVD2800...
    You could also try turning down the contrast on the DVD2800 in it;s display settings to see if you can still get a watchable image and stop it from blue screening at the same time.
    Gordon
  9. laurie
    laurie
    Nov 23, 2001
    145
    16
    Sydney Australia
    Jason
    Is the problem there when you feed it an interlaced output from the Denon and what about RGB!!
    cheers Laurie
Thread Status:
