futureal33
Evening all,
Im looking at getting one of the new WD TV Live hubs, which will connect to my WD Live 2TB NAS drive which holds all my movies.
I have just upgraded all my network gear to gigabit speed devices (switch, router etc) and am just wondering if anyone knows if the WD TV Live is 10/1000 (gigabit) also? I assume it is...but cant find anything on the specifications of the device anywhere!
Also - on a side question, what are the main differences between the new one and the old one, again I cant seem to find much if anything at all that separates them other than perhaps no longer supported firmware on the earlier version?
Thanks for any help
Edit - Just noticed the POHD Mini2 is Gigabit connection, this sounds much better! However the reviews of this device aren't as good as the WDTV!
Can anyone help me out?
All i'm looking for is a Media Streamer that will play X264 media (which is held on a WD Live 2TB NAS Drive) - routed through a Gigabit switch.
The media player will also be connected via a wire to the same switch.
Please help me pick a streamer that fits my needs, thank you
Thanks for any help
