WD TV "High Definition Multimedia Adapter" - Part 1
Status
Not open for further replies.
YellowSphere
Just read about this over at HCC.com.
Looks like a decent bit of kit, much more functional than the USB ports on DVD players that I've seen. Support for MKV files is very interesting too, as well as the expected price.
Can find it on Western Digital's site here.
YellowSphere
Ooh, thanks for that review. Looks like it has a few drawbacks, but well worth the money. I've been interested in things like this for a while, but I've always been put off by the fact that I probably wouldn't use them that often and so don't want to spend much money. This looks like it'll do a good, although not perfect job, for playing the occasional video or JPEG slideshow on.
robtek70
Does anybody know if the USB port will support an external USB DVD drive. I have a lot of movie files, of various types, saved on dvd and would like to be able to play them with this player. I already have an iStar, which does the job very well, but need something for my bedroom.
Trune
This looks great.... just what ive been waiting for.
only draw back for me is lack of network port, does anyone know if NAS drives with usb ports can be on NAS and USB simultaniously?
DeathFromAbove
This looks really interesting, but the following comment on the WD specification page is a little worrying:
- An audio receiver is required for surround sound output. AAC/Dolby Digital decodes in 2 channel output only
Does this indicate a lack of 5.1 (or higher) via HDMi or optical?
robtek70
Just placed a pre order for one at Play.com, available from 17th Nov.
energy80s
This thing sounds really interesting, and only costs 80 quid. The BIG drawback is the lack of an ethernet port. Is there any way (or any gadget) that would let you connect a LAN to the USB port and allow you to browse media from a network server using Samba shares??
Trune
Can you explain what you mean here? and what conclusion you came too?
Trune
I very much doubt it... it would require drivers to install a usb - network adapter.
So you would need a USB drive.
However, i was hoping that i could get a NAS with a USB port, and use the network port and usb port at the same time, can anyone confirm if this works on most devices?
YellowSphere
The documentation is stating that, whilst the box can decode DD, it can only output as two channel PCM. This is always what happens if you try to send PCM via optical. Presumably, they just didn't want to implement it via HDMI, and that's fine, because the optical output will still bitstream Dolby and DTS to a receiver to be decoded there into proper 5.1. Sorted.
I would also assume that it doesn't bitstream via HDMI, so you'd need to connect it by optical for surround sound no matter what, like a Sky HD box. I could be proved wrong here, but I doubt it...
DeathFromAbove
No probs pal... :)
I was worried that the 'AAC/Dolby Digital decodes in 2 channel output only' statement suggested 5.1 soundtracks (ie. DD and DTS) were reduced to 2.0. But the MaddHat reviewer got Dolby Digital 5.1 and DTS 5.1 through his amp from the WD HD TV.
I'm looking forward to seeing a couple of forum-user reviews, as this sounds ideal for my needs!
willo
Just a thought but it could be possible to hook up a My Book (the NAS one) via usb to the WD TV and then attach the My Book to your network. Can’t see why it wouldn’t work unless the My Book cannot do both.
KyleS1
Me too. Looks like an ideal step between my philips 5980 and a PCH. While the popcorn hour is great, it is expensive and does a lot more than I would need. This look perfect. Only thing I am concerned about, as other are, is the lack of ethernet port. Will see what people say about using the My Book NAS drives via USB and Ethernet.
YellowSphere
which HDMI version is it? Does it pass the new audio codecs?
Highly doubt it, but I really wouldn't expect it too. If you want lossless audio, buy the Blu-Ray......
Patient
If this had an ethernet connection it would be ideal - anyone know of a device the same as this but with ethernet?
energy80s
Not sure - is USB fast enough to stream HD content?
Well, USB2 certainly is (it's nearly 5 times faster than standard ethernet) but whether the WD player would recognise the information as it would be coming from an IP address rather than a hard drive file system is the problem.
Why the hell WD didn't stick an ethernet port on this device I'll never know. Without it, it severly limits its potential (and therefore WD's potential to make money!).
robtek70
Status
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
Latest News
Philips unveils A7507 TWS headphones and new rugged outdoor speakers
  • By Andy Bassett
  • Published
Philips FB1 soundbar will use Fidelio wireless platform
  • By Andy Bassett
  • Published
Philips announces OLED807 and 8807 The One TVs for 2022
  • By Andy Bassett
  • Published
Lenco launches 400 series turntable and speaker combo
  • By Andy Bassett
  • Published
AVForums Podcast: 26th January 2022
  • By Phil Hinton
  • Published
