WD TV - Don't have firmware upgrade button! Help!
Searcher2
I bought a second hand WD TV last year and have decided to upgrade the firmware. The firmware is currently 1.02.08. However, following the instructions I don't have an 'Upgrade Firmware' icon in the Settings.
Anybody any idea how I can get it upgraded? I've done a factory reset but that didn't help.
Searcher2
Yes - and put it in the root directory on my 16GB SD card.
But your tip helped as when I looked on the 16GB card to double check the 2 files were gone. I put them on again and the same thing happened - they were removed by the WDTV box.
I put the files on a 2GB SD card instead and repeated the procedure and the Firmware Upgrade option appeared and worked.
Thanks!
