The cables that I am looking to use are by the chord company any recomendations which one from
1) Chord Signature
2) Chord Anthem
3) Chord corous
speaker cable is the new Chord Epic
RustyZip said:Instead of the P7, why not buy 2 P1 Mono Power amps (for front L & R) and a 3 channel P35/3 power amp for the centre & rears, although if you are using a 7.1 speaker setup, your going to need another P35 power amp...
Thats what i did, and its (supposed) to blow the socks off of a P7 (never heard a P7 myself though)
If your using 5.1 setup, i would imagine they would roughly cost the same - give or take a £100 or two...
thatMikeguy said:If you can afford the space and the $$$ for the P1s and P35/3 then it would no doubt be divine.
