Wave interference on Philips 963sa
Discussion in 'Blu-ray & DVD Players & Recorders' started by GPMCDERM, Sep 4, 2003.
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Only notice this on dark back backgrounds....when used with
    Panny AE100.
    I've used it with RGB scrat and does not show up, Got a good
    component cable(want to be for 100 euro+) and best way to
    describe the interence is its like waves accross the srceen
    I'd say its always there but seen clearly on dark images.
    Any ideas what it could be....have kept the mains cable
    away from the component lead as much as possible.
    Ger
  2. robbster
    robbster
    Jul 20, 2003
    391
    +13
    Hi Ger
    Funnily enough I was messing around with my setup today and noticed some interferance like you mentioned through the component output. I have a plasma screen and a denon 2900 and noticed it first on a blue background that the DVD player outputs in stop mode. This was in interlaced mode when I saw it, on switching to progressive scan the interferance went away and looked solid like it does in RGB.
    I know I have a different setup to what you have but are you displaying the signal in progressive or interlaced?
    Rob
  3. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    I use it in progessive all the time for both Pal/NTSC
    Ger
  4. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Ger,
    Is this the vertical stripe problem ? Grey/green stripes, declining in intensity from left to right ?
    Cheers, Carl.
  5. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    No, just like a wave moving from left to right at a slant......I'm
    all for buying good cables as theres no point paying good money for 2 bits of kit and having 50 pence holding them together but
    I assume the cable is good so....haven't noticed any interference
    from other sources connected to the projector which is why I'm
    looking at the Philips.
  6. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    I have a dv88p+ and a sim2 and I get faint wavering lines as well. I've ordered some filters to see if that will work - I'll let you know.
    CaM
