Wattgate alternative?
Discussion in 'Cables & Switches' started by t0by, Mar 23, 2006.
  1. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    I've just bought some Wattgate 320i's to make up some home brew power cables for my AV kit but the bu**er won't fit into my Panny PW7 plasma. Should have checked first!
    So anyway, I need an alternative recommendation please, if anyone has any ideas? I'm combining with Supra Lo-Rad mains cable and an MK Duraplug.
    Thanks.
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
  3. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Isn't there a proper panny power lead that fits into the bracket to stop it pulling out - or am I thinking pioneer XDE?
  4. Dean25
    Dean25
    Aug 7, 2005
    135
    Reading
    +8
    You should be able to get some decent slimline iec plugs, that will fit the supra, try www.audusa.com as they sell a martin kaiser iec silver plated for about £8.00 or failing that try supra themselves as I am pretty certain they make an iec plug for the lo-rad cable. With regards to the wattgate you should be able to sell it on for about £12.00 including postage.
