wats going on at crystal palace?
Discussion in 'Freeview & YouView' started by DaveLeach, Feb 10, 2009.
  1. DaveLeach
    DaveLeach
    Dec 27, 2008
    60
    i cant recieve itv etc. checked the fretv site, and it shows low signal from the transmitter. anyone know what this is all about and how long it will last
  2. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    Gizza link
  3. DaveLeach
    DaveLeach
    Dec 27, 2008
    60
  4. radioredcat
    radioredcat
    Jul 4, 2008
    620
    28
    st helens
    +71
    It seems your not on your own MUX 2 UHF CH22 there has been several complaints about that particular mux,People have contacted them and they no work apart from the radio side.
    http://www.digitalspy.co.uk/forums/showthread.php?t=981581
    People have been having problems who are not far from the transmitter as well.
    andy
  5. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    The Maximum/Low category on that page is misleading as it is only comparitive to other Muxes from same place. Here all are 20kW - the 64QAM ones show Low compared to the 16QAM but the effective power reduction is small. Add a 5kw and IT would be shown "Low" and 2/A become "Medium".
    As already said, others have same problem. Is it all the 2/A channels weak, or just the 2 ones?
  6. DaveLeach
    DaveLeach
    Dec 27, 2008
    60
    that has gone straight over my head!
    is there any way i can get these channels then??
  7. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    Dunno! Where are you? What does wolfbane say? See FAQs.
    As to the "overhead" what I am saying is that the "Low" is misleading and should say "a little less high" so should only make a difference if you are very marginal.
    Have you asked around locally to see if others get same as you?
  8. DaveLeach
    DaveLeach
    Dec 27, 2008
    60
    sl3 8ey
  9. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    I recognise that postcode. Have we already had this discussion on another thread?
  10. radioredcat
    radioredcat
    Jul 4, 2008
    620
    28
    st helens
    +71
    Here's something to try if you have a wireless access point/modem router try switching it off and anything else wireless just to rule it out.
    We recently had a case in similar circumstances.
    What scribbler was pointing out is channels that are 64qam need more signal than a 16qam channel,so in the case of C/P all the mux powers are 20KW so mux 2/A are going to appear weaker than the other four.
    let us how you get on
    andy
