waterproof camera
Discussion in 'Photography Forums' started by happychappy, Jun 16, 2004.
  1. happychappy
    happychappy
    Nov 17, 2003
    333
    londoniumish
    +45
    Can anyone advise me of a totally waterproof camera (up to around £400.00) I need it for a holiday in which I intend to take pictures of my family swimming in the sea?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,357
    Rainham Essex
    +2,442
    I don't know if you can buy a waterproof camera, but what you can do is get a waterproof houseing to put the camera in such as:
    www.xlshop.co.uk
    Manufacturer Code:WP-DC900
    XLShop code:CAN-WPDC900
    For use with: Canon PowerShot A80
    £149.99inc VAT
    Fits the PowerShot A80. You can use this case to take underwater shots at depths of up to 40 meters (130 feet). And of course it's also ideal for taking worry-free pictures in the rain, at the beach, or on the ski slopes
    and the camera:
    Manufacturer Code: Canon A80
    XLShop code:CAN-PSA80
    • 4 Megapixel resolution • 3x optical zoom lens • 3.6x digital zoom • Movie capture mode • Sound memo feature • CompactFlash memory card slot
    Dimensions: 103.1 x 64.6 x 34.7mm
    £231.19inc VAT
    The above is just an example of what is available and may well be available cheaper if bought from another e-tailer etc.
    The advantage of going this route is that you also have a very good camera for everyday use.
    Mark.
  3. matiano
    matiano
    There is a similar 'waterporof housing jobby' available for the Olympus Mju 300. I would reccomend trying to get hold of one well in advance of when u leave though.
    Alternatively Pentax do a 'water resistant' model, whilst u wont be able to dive underwater with it as far as I can tell it should suffice for holding above water in the sea and taking some snaps.
    http://www.jessops.com/search/viewp...=&SHOWCASEID=&STARTROW=1&SUBS=&WORD_SEARCH=N&
  4. JUS
    JUS
    Jan 21, 2003
    3,433
    Plute
    +320
    You can buy totally waterproof cameras. A couple I know have a driving camera they use on holidays. I've been on holiday with them a few times and they always take it and use it as a normal camera. Pictures are OK. Not sure, I think it's a Minolta.
    I'll ask him where he got it. Probably a Paddy dive shop.
  5. Brian110507
    Brian110507
  6. happychappy
    happychappy
    Nov 17, 2003
    333
    londoniumish
    +45
    Thanks everybody for your replys, I now have a bump-steer in the right direction, on another note has anybody any links to reviews of any of the cameras mentioned?
    Thanks again in advance :thumbsup:
  7. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    The Garden of England
    +32
    I've got a case for my Canon S45 and wouldn't be without it now...
    No worries about being on the beach (sand and sea wise) as well as the benefit of some very original pictures..!!!
    I've also got an EWA Marine Case for my Camcorder... another thing I wouldn't be without either... same reasons as above.....
    Even the Mrs thinks both were good purchases...!!!
    Highly recomended..!!!
  8. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    The Pentax Optio 43WR is about £280 and small.
    It is waterproof, and can be submerged but not operated underwater. It has a 4mp sensor and optical zoom
