Water Filter Jug
Discussion in 'General Chat' started by alphaomega16, Jul 2, 2015.
  1. alphaomega16
    alphaomega16
    May 17, 2005
    14,182
    163
    Southend on sea
    +3,803
    Ok, since the weather has picked up I have been consuming more and more water and since I am not a fan of the tap and have been getting bottles of water can anyone recommend a decent Water Filter Jug.
    Would like a sizable capacity and able to fork out up to around £30.
  2. a l e x
    a l e x
    Jan 3, 2009
    7,861
    East Yorkshire
    +2,694
  3. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,287
    +7,408
    I have the same one. There are often deals on multi-packs of the cartridges. I ignore the display & only change it if I can taste it isn't working properly or the flow slows too much. At least I did in the early days as the display has long since died.
  4. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
    Tesco do their own brand filter refills that fit the Brita's :smashin:
  5. alphaomega16
    alphaomega16
    May 17, 2005
    14,182
    163
    Southend on sea
    +3,803
    How long is that argos one on offer for, I couldnt see.
  6. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
    I looked and couldn't see either, I also have an email from them regarding the sale but that said nothing.
    It is that price on amazon too if that helps :smashin:
  7. amd mad
    amd mad
    Mar 13, 2007
    832
    63
    +298
    I got ours from Tesco xl was on offer £11 we use tescos own filters .
  8. SBT
    SBT
    Mar 19, 2011
    11,150
    +5,831
    Doesn't bottled water work out cheaper?
    A water metre + cartridge replacement can't be cheap.
    I've binned my receipt but I know the bottled stuff I buy is pretty cheap.
  9. Digital Tench
    Digital Tench
    Dec 16, 2004
    4,316
    South London
    +906
    Not when you factor in shoe leather and the portable air con costs you would need to go the shops it wouldn't :)
  10. SBT
    SBT
    Mar 19, 2011
    11,150
    +5,831
    Get it delivered with the rest of the shopping.That way you can stay indoors enjoying the AC :D
  11. alphaomega16
    alphaomega16
    May 17, 2005
    14,182
    163
    Southend on sea
    +3,803
    Wish we could afford AC, apparently a 3 bedroom home with 2 PC's, 2 TV's and sky boxes and the usual kitchen stuff uses ~17kw per day.
  12. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    Go to the Brita website and they'll send you a new meter free so long as you quote the serial No on the side of the meter. That's if you can be bothered :)
  13. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,287
    +7,408
    Useful, which is more than meter is! ;)
    Think it's just a mechanism to get you change cartridges totally unnecessarily.
  14. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    I can't remember whether I mentioned it in another thread but I have one of the same jugs that supposedly monitors water quality and actual usage as well as a water boiler with a simple 4 week count down timer. The magical meter told me to change filter exactly one day after the four weeks were up on the water boiler. I'm quite tempted to take it out and see when it tells me to change the filter with zero usage :)
  15. Epicurus
    Epicurus
    Jan 17, 2006
    3,709
    +696
    The Brita "metre" is just a 30 day timer.
  16. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    There are two types, one is a simple count down timer, the other has probes that detect how frequently the jug is used, although I suspect it is "mostly" a count down timer too ;)
  17. alphaomega16
    alphaomega16
    May 17, 2005
    14,182
    163
    Southend on sea
    +3,803
    But then you are left with loads of bottles lying about, lot easier with a filter jug and just pop it in and out the fridge.
  18. SBT
    SBT
    Mar 19, 2011
    11,150
    +5,831
    Why would you keep the bottles?
    Just chuck them in the bin.
  19. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    If it's the economy stuff for 17p for 2 litres then you could have 246 litres out of the tap for the same amount of money. The Brita filters reckon they are good for 100 litres, so lets go with 100 for the calculation.
    100 litres of cheap bottled water costs £25.50
    100 litres of filtered water costs 7p for the water and £2,66 for a maxtra cartridge (from Boots at the moment).
    So your bottled water is nearly 10 times more expensive.
  20. SBT
    SBT
    Mar 19, 2011
    11,150
    +5,831
    Oh well, I'd stick with the jug then.
    I'm not that much of a water drinker anyway. The bottles I do buy, I put squash in and take to bed. Plus they come in handy if I get caught short :D
  21. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    This comes under the heading of deliberate thread spoiling just to gain notoriety. Please cease and desist, you are slipping back into your old ways.
    • Agree Agree x 1
    • Funny Funny x 1
    • List
  22. amd mad
    amd mad
    Mar 13, 2007
    832
    63
    +298
    As long as SBT don't mix up his bottles in the middle of the night .
  23. alphaomega16
    alphaomega16
    May 17, 2005
    14,182
    163
    Southend on sea
    +3,803
    lol
  24. Showoff
    Showoff
    Dec 15, 2008
    3,502
    +3,243
    • Like Like x 2
    • Agree Agree x 1
    • List
  25. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
  26. BT Bob
    BT Bob
    Nov 22, 2006
    2,442
    116
    Cardiff
    +1,210
    When we had our kitchen re-fitted a few years ago, we invested in a Franke Triflow filter tap - haven't looked back..
    Bottled water has a place, but the environmental impact of all those bottle sitting on supermarket shelves, is terrifying....
  27. Showoff
    Showoff
    Dec 15, 2008
    3,502
    +3,243
    Nope, it comes with everything you need.
    The self piercing clamp fixes onto your water feed with one piece of the small blue tubing going from the clamp to one end of the filter and a second piece of blue tubing from the other end of the filter to the tap.
    The hardest part for me was drilling through a German built sink to fit the tap. I broke the first self tap drill bit I used and had to buy a stronger one.
  28. Bubblin
    Bubblin
    Nov 12, 2006
    1,331
    116
    Medway
    +707
    We have the official Britta one, has hot, cold and filtered water on a single tap unit, refills last a year (about £35) and filters water on demand, I think the tap costs about £125 and just replaces your current mixer tap, so no need to drill extra holes in your
    BRITA Household | Pressurised Systems
  29. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
    Ordered ! :smashin: Bye bye Brita :hiya:
  30. alphaomega16
    alphaomega16
    May 17, 2005
    14,182
    163
    Southend on sea
    +3,803
    Let me know how you get on mate.
