martian1
Hi all just after advice yesterday I decided to swap a sound card out I put in PC a couple of weeks ago 2min job I thought but I found a patch of residue on the backplate of my 1080ti GPU it was around 30mm in diameter and obviously a leak from the CPU block fittings. I have taken card out and tightened joints up and ran PC briefly via onboard graphics and all seems ok and I could not see any leakage. Anyone with experience think this is just a joint that's worked loose I only tighten by hand so perhaps I need to apply a bit more force..my main concern is it's a faulty coupling pretty sure they are ek compression fittings.
Advice help appreciated
