Watching WMV Hi-def on pc
Discussion in 'General TV Discussions Forum' started by McGraw, Mar 3, 2005.
  1. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    I have a 3.2 Ghz pc with a 256 mb graphics card so I meet the min specs for hi-def Windows media files.
    I also have an lcd monitor tha runs at max 1280x1024.
    I am in the process of downloading some test material at 720p.
    The question is, what resolution should I set my monitor to?
    Do I need a custom res to get the best picture or will scaling happen no matter what.
    Thanks a lot.
  2. Master Rahl
    Master Rahl
    No. Just set it to 1280x1024. The empty spaces at the top and bottom will be blacked out by Windows Media Player.
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +921
    Your display is 4:3 1280x1024. The 720p Windows Media will be 16:9 1280x720. The horizontal resolution is identical. When the 16:9 material is displayed it will be letterboxed to the central 720 lines, and not require scaling in either direction.
    You won't need to scale or change the resolution. The 304 extra lines on your 4:3 display (1024-720) will contain black, 152 lines above and below the active 720 line picture.
  4. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    Thanks very much.
  5. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    And it does look fantastic :) There's quite a lot of trailers etc on Microsoft's WMV-HD site. Also a German company has released some DVDs with WMV-HD films on, I have Underworld: Director's Cut and Tomb Raider...maybe not the best choice ;)
  6. mattross
    mattross
    Oct 23, 2004
    265
    +7
    Incidentally, Windows Media Player requires a lot more resources to play HD WMV than Zoom Player Pro WMV. On my lowly 1.4GHz AMD Thunderbird PC with a 128MB Geforce 2 GTS graphics card I can get HD sources playing perfectly, with the audio fully synched, as long as I use Zoom Player. With WMP it's horrible, the audio and picture stutters continually.
  7. probedb
    probedb
    Aug 20, 2003
    2,660
    Sheffield
    +180
    From reading the AVS forum I think WMP has something in it which tries to keep audio and video synced which keeps it juddering. Obviously not doing a very good job though :)
    Does ZoomPlayer support WMA5.1? I have an NForce2 mobo which converts the tracks to DD5.1 when I use WMP.
  8. mattross
    mattross
    Oct 23, 2004
    265
    +7
    I believe it uses whatever codecs are already installed by WMP. Not sure though as I only use mine currently to play on my PC monitor with crappy monitor-mounted speakers. I need a better soundcard with SPDIF and a graphics card with DVI out before I can test it properly.
  9. loz
    loz
    Jun 4, 2001
    13,062
    +1,787
  10. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Cheers for the info will be testing & if it all works out i could save a bundle when i build my HTPC
