Watching SKY via a PV500
Discussion in 'Plasma TVs Forum' started by seasider2, Aug 29, 2005.
  1. seasider2
    seasider2
    Jul 19, 2005
    65
    Hi all - had a Panny PV500 42" for about a month now. Watching terrestrial channels and DVD, the PQ is brilliant. However, when watching SKY it is terrible, doen't seem to be able to handle the picture at all - colours all over the place, images pixelated etc. I have a top of the range IXOS scart as well. :mad:
    Anybody else experience this, and advice?
  2. pixelated
    pixelated
    Feb 12, 2005
    1,845
    +94
    It's that bad? :confused: I hope this can be sorted out! I've just bought one (well about a month ago) and it's still in the box while the room is finished lol Hmmph... let's hope there is a way to improve the Sky quality from what you're experiencing...
    Stu
  3. Rapid 17
    Rapid 17
    Jan 14, 2005
    891
    28
    +78
    Mines very good with SKY and DVD's but not very good with analogue.
  4. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Sounds wrong to me. At the risk of teaching you to suck eggs, have you got a dedicated scart going from SKY RGB to the PV500 AV1 (RGB)? Also, have you set the Mode for each input, so that AV1 is set to Cinema? The SKY PQ on my set is superb, so I do find your problem a bit confusing...
  5. RayB
    RayB
    Mines also fantastic with Sky,
    Sulis has given good advice, must use RGB Scart out to AV1 in etc.
    If images are pixellating badly I wonder if you have a problem with your Sky box/dish etc - maybe a poor signal etc
  6. pwood
    pwood
    Dec 6, 2003
    2,549
    Central Scotland
    +158
    Sky looks fanatastic on mine so I'd say something is amiss. Try a different fully wired scart lead into AV1 and AV4 just to be sure it isnt faulty and or the scart sockets on 500 arent faulty. Make sure Sky box set to RGB and save settings on skybox. When switching the inputs on your 500 the screen should say Av1/RGB once selected. Even the none RGB output looks pretty good on my set.
  7. seasider2
    seasider2
    Jul 19, 2005
    65
    Thanks Sulis, I'll check out the inputs. Incidentally, I'm still waiting for the remote control to arrive (wasn't in the box :confused: ) so I can't change the mode's - maybe that will help.
    The sky signal, is about 1/4 bar strength, and a 1/2 bar signal quality.
  8. neilmcl
    neilmcl
    Oct 29, 2004
    6,224
    103
    Nottingham
    +289
    What :eek: no remote. You sure that this was a brand new set and not a previously returned model. Maybe the original owner could have half-inched the remote.
  9. seasider2
    seasider2
    Jul 19, 2005
    65
    At first, I was suspicious myself but the set and everything looked untouched. The batteries for the remote were still sealed in the accessories box, but no remote. The company has had to order one from Panasonic, after accusing me of trying to pull a fast one that is.
  10. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    No remote, i would pretty much say the tv is set to dynamic which would cause the the problems that you have mentioned. Dynamic is crap and it wont be doing your set any good if it is in this mode,cant you have the firm you got it from loan you a learning remote with all the basic feutures copied to it so you at least can alter some of the modes.
  11. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Dynamic Mode would certainly look a bit rough, but there may be some connection issues as well. I'd really beg or borrow a remote to change it to Cinema mode as quickly as possible - I'm afraid you can't change Modes from the panel on the front.
  12. John-D
    John-D
    My Sky looks great, too. My digi box is one of the original pace boxes and is nearly 8 years old (dont laugh...lol).
