Question Watch Tivo recordings anywhere
Discussion in 'Cable TV & Virgin Media TV' started by garyc, Jun 9, 2015.
  1. garyc
    garyc
    Dec 21, 2002
    918
    Jersey, Channel Islands
    +17
    Is it possible to watch recordings made on the Tivo media box in a second home etc?
    Cheers gary
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,627
    Redditch
    +4,208
    Google Slingbox
  3. dante01
    dante01
    Mar 5, 2009
    46,618
    +11,232
    No, Virgin Media unfortunately do not facilitate this. You can view some content recorded on the TiVo via another TiVo within the same home, but you you cannot access the content on a TiVo from a location away from home. Even the content you can view on home is limited due to the copyright restriction imposed by the content providers.
    If using a device such as the Slingbox then you'd be limited to SD output to it. I'm under the impression that Slingbox don't natively support the VM TiVo, but the V+ command set which is supported can be used to control the TiVo.
  4. garyc
    garyc
    Dec 21, 2002
    918
    +17
    thanks guys
    slingbox only SD output that's sad:(
  5. dante01
    dante01
    Mar 5, 2009
    46,618
    +11,232
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,627
    Redditch
    +4,208
    Your broadband connection upload speed would probably rule out HD anyway.
    They quote 600kbps, that's not going to be HD as you know it. Check out the download speed required for iplayer-HD.
  7. Headbangerdaz
    Headbangerdaz
    Jun 20, 2008
    373
    28
    +33
    You can't even watch recordings in the same house on other devices (mobile,pc) can you ?
    You can only watch live broadcasts
    At least that's how I understand it
  8. dante01
    dante01
    Mar 5, 2009
    46,618
    +11,232
    You can watch some content recorded on a TiVo via another TiVo in the same household, but Virgin do not facilitate a means by which to stream or convey content recorded on a TiVo to other devices such as a PC or mobile device.
