Was going to buy an OLED, but...
kj01
I'm new here, but don't get me wrong, I'm not here to cause trouble: I think the standard of so-called HDTV has become absolutely lamentable of late.
Whatever the platform, absolutely awful - especially the Wimbledon tennis on BBC.
So, abandoned the whole idea - I'll stick with my 42" LG plasma. Very sad.
RayP
I don't know what TV you were looking at to come to that conclusion but I can tell you pictures of tennis (and every HD channel) are absolutely brilliant on my Loewe OLED. As someone who had a Panasonic plasma display until last November the upgrade is significant.
dave1956a
+1 same on my LG 55 OLED it walks all over a Pana 50VT65 (even SWMBO can see how much better the oled is)
google
What idea did you abandon? Were you going to go 65"? I think you would enjoy oled over the plasma.
GAmbrose
I still have my 55VT50 in the bedroom and the difference in image quality between that and my 65B6 is night and day.
OLED is so good
steelman1991
Yip - it's all OLED's fault that transmitted TV is crap.
RayP
Buy the right OLED and it will do a great job of poorer quality transmissions. Worth the upgrade IMHO.
The quality of the Freeview picture on my admittedly expensive Loewe is outstanding. But only yesterday I found that switching to 1080i in my Sky Q box improves SD PQ no end and is far better than the lazy option of leaving it to 3840*2160 for all sources. HD broadcasts are slightly better too. Well worth the effort in switching only to 3840*2160 when you want to watch UHD.
Slugsy01
I walked into Currys and they were showing tennis on the Sony OLED.
It looked AWFUL, loads of artefacts, lack of sharpness etc.
Do I think that it's because of the set or its an OLED? No, because Currys had set it up terribly and it looked like a non HD channel.
That set is a diamond as are many other OLED. No set will do well under those circumstances.
If I was buying a set now, OLED is easily the choice I would be making. Other than some minor quibbles about brightness in highlights with HDR, I'm not sure what else I would want.
kj01
That's the sort of advice I was hoping for. I'm thinking that the sort of stuff I want to watch will only be available in "HD" for some time to come, and anyway, Sky want another arm and a leg for Sky Q - enough is enough. With the sort of viewing distance envisaged, a decent quality HD picture should be quite adequate. Accent on "decent quality"...
It seems that HD is becoming the new SD, with ever-reducing bandwidth and ever-increasing compression (to make way for the bandwidth requirements of UHD channels). Well, that's the impression I'm getting.
So, which would be the "right" OLED TV? Being a cheapskate, I was toying with the idea of an LG 910v, but the 55B6 might be a better bet for the future...
(Many thanks for all the helpful replies, by the way...)
furryhobnob
The 910 is only a 1080p oled with no hdr, although great not really future proofed, and for the same price as the b6 you can get a c6 that also has 3d that the b6 doesn't have, and a better chipset than the b6 also, my last TV before going for oleds was a Panasonic zt65 which was Panasonics best consumer plasma ever made, and oleds make that look like a poor TV, still own a Panasonic vt65 in the bedroom and the difference is night and day
HP Deskjet
I made the same move, only my VT50 was 55". I find my 55" LG E6 OLED far better, even when it comes to motion handling. The blacks are obviously better than those on my VT50. I can safely say that the LG 55" E6 OLED is the best television I've yet owned. I've watched a lot of Wimbledon on it this year and have had no complaints about the picture quality.
gbjbaanb
OK, so which one is the right one? A sony? Panasonic? A LG even? Or a Philips or Loewe?
I don't expect SD broadcasts to look magically better because they're on an OLED (as I think many people do reading the comments that its not OLEDs fault SD is not 4k HDR), but I expect them to be easily watchable with no blockiness, upscaling artefacts, or motion problems.
RayP
Buy a Loewe Bild 7. Okay, I know it's serious money but having had a 3 hour demo of it at ********'s pad last October I placed my order within 48 hours.
I thought Blu-ray was 4K it was that good. Even some Sky channels have seriously good PQ. I'm still able to watch DVDs on mine and not be irritated by the poor resolution. Yes of course it's only 720x576 but such are the upscaling qualities of the Loewe it makes all formats watchable. And Dolby Vision is superb.
And with Sky Q the SD quality can be improved by setting Sky to 1920x1080 for SD and HD content and only switching to 3840x2160 for UHD content. Bit fiddly I know but ask yourself what's going to upscale better? A Sky box or state-of-the-art TV?
Nine months on and I still feel no regrets about spending the money. You really do get what you pay for with Loewe.
Stitch
I think the 2017 screens are all very capable. Personally, I have the Loewe Bild 7, but suggest you need to go see for yourself. Don't think you'll be disappointed with whichever one you decide on.
Off The Fence
I'd say if you've got the cash, go for a Bild 7 (as alledgedy they have cherry-picked panels and so you're less likely to get a bandy one...and owners banging on about how amazeballs they are at abso-flipping-lutely everything :p).
After that, if getting the most out of low quality /SD sources is a priority, I would go for a Sony or Panasonic (this is after lurking on the OLED forums for ages and finally setling on an A1 for mostly HD/broadcast viewing).
toodeep
With respect what does the Bild7 give one that the newer cheaper Bild4/5 lacks, apart from a motorized stand?
RayP
The very best LG panels. Only available for the Bild 7. Hence the outstanding PQ.
RayP
Would those be last year's panels or this year's? Are the Bild9's panels better still?
Both years. The 2016 panels of which mine is one has 3D capability. The 2017 ones don't.
Can't speak for the 9 as I don't have it.
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
Latest News
What's new on UK streaming services for November 2021
  • By Andy Bassett
  • Published
PROMOTED: Which OLED is King? 2021 Shootout at Abbey Road Studios
  • By Promoted Content Poster
  • Published
Hisense TVs get Disney+ on VIDAA smart OS
  • By Andy Bassett
  • Published
Astell&Kern launches entry level SR25 MKII portable music player
  • By Andy Bassett
  • Published
LG rumoured to release 97-inch OLED TV in 2022
  • By Andy Bassett
  • Published
