Of specific interest in this case is terms 3.120 (they can't force you to contact microsoft), 3.109 (the MS warranty is binding on the seller), and 3.67+3.87 (you have the right to use it to make sure it works properly first!)
So basically as long as you buy from a UK seller you're covered.. don't worry about it.
