RJay
Established Member
I bought a JBL On Stage 400p ipod dock from my local electric showroom in Aug 2010 for my daughter.
It stopped playing the ipod and after having a quick look it seemed as the docking point had come away from the circuit board.
The store called my up and said it wouldnt be repaired under warranty as it had been broken.My daughter said all she ever done was dock the ipod and un-dock it (with the correct spacer in place).
Where do I stand with this as my argument is it isnt fit for intended use.
Thanks in advance.
Ray
Thanks in advance.
Ray
