WAP setting on a QTEK 8080
ghinzani
Established Member
I dont suppose anyone knows what these would be for O2? When I asked O2 they didnt! Not a great surprise I know but.... Im not on a contract that has 100 mins a month of WAP or something but I've never been able to use it in the 7 years or so since its been part of my package. Would'nt mind cracking it as I'm going away for xmas and it would be useful.
Any pointers muchly grateful for!
Daddy k
do a search on xda devs, but to be honest it should be the same as putting setings in for all other windows mobile devices, so just follow those.
ghinzani
Established Member
Cheers for that BDK. When I asked o2 they gave me the following, but altho its for an o2 x1 which is the same as a Qtek 8080 it doesnt seem to like it:
If you have an O2 X1, you will need to follow these instructions to manually enter the O2 Active settings into your handset.
Step 1 - CSD/GPRS WAP settings
Press Left Softkey (LSK) after entering each option
1.
Use the Red 'End Call' key to clear any text
2.
Menu (LSK)
3.
O2 Active (LSK)
4.
WAP Profiles (LSK)
5.
Choose an Empty Gateway Profile ? Press OK and enter the following details:
6.
Default: if it is the only profile ? this will be set
7.
Homepage: wap.o2.co.uk (. = # key x2)
8.
CSD:
Username: o2wap
Password: password
Dial-up Number: +447712927927 (+ = * key x2)
IP Address: 193.113.200.195 (Dots enter automatically)
Data Type: ISDN - use Green 'Call' key to select and Red 'End Call' key to exit
Data Speed: 9600 - use Green 'Call' key to select and Red 'End Call' key to exit
Idle Timeout: 3 Minutes - as above
9.
GPRS:
Username: o2wap (Pay Monthly users) or payandgo uk (if you have to top-up your phone)
Password: password
APN: wap.o2.co.uk (enter this if you pay monthly) or payandgo.o2.co.uk (Pay & Go users) (. = # key x2)
Bearer: GPRS Prefer
Connect Mode: Continuously
Security: Off (untick with green ?Call? key)
Show Graphic: On
Rename: o2wap
Am I missing something fundamental? Those instructions I have used the data from to fit in where I can on the 8080. Really I am going to upgrade to something with wireless capabilities but amd not going to do that until I move house hopefullyin the next few months so just want soemthing to tide me over.
JayCee
Outstanding Member
Don't forget after altering/changing settings you have to reboot the phone before the new settings take effect.
⭐ Bowers & Wilkins 600 S3 Home Theatre Speaker System Review
Back
