Wanting to buy a good television to go with my Xbox one
Discussion in 'What Is The Best TV For You?' started by seale2014, Aug 29, 2013.
  1. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Any suggestions ? I am looking for 32 min and 42 max. Trying to get one as cheap as possible too. Thanks.
  2. VEGACORTEZ
    VEGACORTEZ
    Aug 6, 2006
    509
    43
    +212
    The cheapest but good with low input lag is the samsung F5000, 16ms input lag, in 32" and 42"(won't be a samsung panel at his size), it's £280 for a 32".
    The tv with the lowest input lag full stop and is a quality lower mid range is the sony W6 series with 6ms input lag, they are around £380? 32" and £550 42".
    Those are the two best options for input lag and picture quality factoring that the tv is only for gaming and not other uses. Panasonic lcds are above 20 or 30ms and offer nothing these cannot do. You can look up the owner threads here on avforums if you like. Hope this helps
    Regards
  3. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Thanks for that. Is there any clear differences between the 2 televisions?
  4. VEGACORTEZ
    VEGACORTEZ
    Aug 6, 2006
    509
    43
    +212
    The viewing angles are better on the sony and i believe it has a slightly less reflective screen. It has superior scaling for non hd sources and obviously better lag. The sony has a better motion enhancer and can be enabled in game mode which is also compatible with RGB 4:4:4 for a crisp picture like a pc monitor. The samsung can only achieve 4:4:4 and it's best gaming picture quality when an input is labelled as PC, this in turn will disable the motion enhancer and limit some of the picture tuning options. The motion enhancer the sony uses eliminates all motion blur at the cost of a dimmer image and some may see a minor flicker, the samsung variation which you can't use when labelling the input as PC removes a little bit but not all blur and does not dim the image as much. As you are console gaming at 30fps most likely on the xbox one the motion enhancers may be of no use as 60fps games benefit most from using motion enhancers. Also be aware that the 42" version of the samsung will not use a samsung screen as they only make 40" panels themselves. I also can't vouch for the panel the 32" sony uses either only the 42" which i have.
    I guess as using an xbox one the scaling is a mute point and as i say motion enhancers are probably pointless for those frame rates or not depending on your point of view so it comes down to viewing angles and input lag and price and size. If you want 32" then the samsung may suit your needs better and if you want bigger then the sony is the better option due to the unknown panel type the samsung may have. Be aware though it not a guarantee that the 32" samsung will have their panel but hopefully it would. You can look up reviews on the 42" sony on * as well as the samsung F5000 32".
    Regards
  5. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Cheers for your time here mate. I'm thinking of the Samsung 32 inch as I'm wanting one cheap as possible and it seems to be good value for money
  6. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    32f5000 les than £300 from John Lewis. V happy with mine although no gaming and just bedroom set
  7. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Cool. How good are the viewing angles?
  8. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Not an issue but then I am watching from pretty much head on
  9. thedude
    thedude
    Oct 18, 2004
    10,118
    Swindon
    +2,057
    If you want cheap by a used tv. People always sell and upgrade. You will get a better value for money with a used one over at the classifieds and some even have warranty. Win win win
  10. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Where did you find out about the 16ms lag from the Samsung?
  11. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    Hoping VEGACORTEZ doesn't mind me answering this but it's HDTVtest mate.
  12. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    So in your opinion this is the best cheap option for a 32inch?
  13. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    Well I own the Sony KDL32W653 and without a doubt, for gaming it is truly an exceptional TV and at £389 I think it's great value for money.
    I've not seen the Samsung UE32F5000 in action but if there's one website I trust other than AVF when it comes to reviews it's HDTVtest.
    The Sammy gets a great review and though the lag is a little higher than the Sony, you won't notice the difference I assure you.
    And given the Sammy is around £100 cheaper, if the Sony is a little out of your price range then I'm certain this will be the next best thing.
    I recall buying a 32" Samsung Series 1 HD Ready TV back in 2005 when HDTV's had just hit our shores and I paid £850 :eek:
  14. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Ah cool. So the sony you have is the one that is mentioned above? Iv never really known much about lag on televisions until recently. So the samsung will run quite good whilst playing cod ghosts on the Xbox one?
  15. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    That's right mate. It seems most people are buying the Sony with next gen gaming in mind, me being one of them!
    Samsung is a premium name when it comes to TV's and I've lost count of how many I've owned over the years. I would be VERY confident that games like Ghosts will play brilliantly on the UE32F5000.
    In fact if we hadn't had the Sony's this year, we'd probably all be raving over this Sammy!
  16. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Well I'm paying my xbox one and add ons off over the next 2 months so I think it really depends how much money I will have when I get paid in November spare to see what tv I get. I can afford the sammy for sure. May try and push to get the sony. Can you link me to a retailer for the Sony please. Cheers
  17. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    Tbh mate, I wouldn't look anywhere else other than John Lewis with their 5 year warranty and great customer service. Whenever I buy a new TV, John Lewis is the first play I look to buy from.
  18. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    How much more better is the sony over the Samsung . What are the major differences ?
  19. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    I think the main differences between the two are that the Sony has Smart TV and wifi built in whereas the Samsung has neither so if those things appeal to you then I'd save the extra and go with the Sony.
    If they don't, I really don't envisage there being much difference in terms of picture quality and as already said, you won't notice the difference in lag.
  20. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    It's going to come down to what I can afford I think haha. Did you get yours delivered online? Or pick up in store?
  21. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    I ordered online, paying the extra for next day delivery as I couldn't wait(!), though you can pick up in store too. The box isn't big or weighty so should go into the back of any car with no trouble.
    What I would say to you is if you were to struggle to afford the £389 but can afford £289-299 and things like Smart TV aren't necessary, go with the Sammy mate. The HDTVtest review suggests it will make a great gaming monitor.
  22. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    I have a mate who works for John Lewis . Trying to see if he can get me discount on the Sony haha. Ill probably go down and pick it up then
  23. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    Well fingers crossed mate :thumbup: The only other thing I can suggest given the Xbox One isn't out until 22/11 is hold off buying the Sony now and with any luck it might reduce in price a little nearer the time.
  24. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    He said he's not gonna risk his discount :( haha which is fair enough. It's only 100 extra but to be honest that 100 could buy 2 more games :p
  25. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Yes but it could also stop you having to buy a new TV in 12 months and 1 week ;) You know John Lewis will match other bricks and mortar stores and you'll get the warranty and customer service
  26. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    Oh yeah ill still be getting it from John Lewis ;)
  27. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    That's one way of looking at it. I'm sure JL have the Sammy in stock too so if you do end up buying that, I'd still buy it from them.
    You'll have your 7 day Distance Selling Regulation rights if you purchase it online (you can purchase online but pick up in store if you prefer) so if it's not for you you can just send it straight back.
  28. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    You can't argue at that. Think I will get the sammy if the only difference is the wifi and smart tv
  29. PA77ULY
    PA77ULY
    May 12, 2013
    1,637
    +149
    Don't quote me on the differences(!) but those are two that spring to mind.
    I'm sure they'll be other differences but I'm sure they're minimal. Worth noting that HDTVtest also reviewed the 42" version of the Sony so might be an idea to check both reviews out :thumbup:
  30. seale2014
    seale2014
    Aug 16, 2013
    110
    Sheffield
    I'm just checking the samsung review on there at the minute will give them a look after
