Wanting Sky - Can I have a loft installation?
Discussion in 'Sky Digital TV Forum' started by dynamite, Aug 20, 2004.
  1. dynamite
    dynamite
    Nov 6, 2002
    73
    9
    Hertfordshire
    Hi Guys,
    I've finally been given the go-ahead to get Sky (or Sky+ as it will probably end up being).
    Unfortunately I can't have the dish on the outside of the building. I phoned Sky today and they said it must be on the outside - no alternatives.
    Now, with all today's technologies, I just don't beleive this. I'd really like it installed in the loft. Any suggestions?
    Cheers,
    d.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Must be line of sight to the satellite!
    contact your local CAi installer, bypass sky monkeys for a discrete install
  3. cerebros
    cerebros
    Dec 27, 2002
    1,293
    48
    Leicester
    +29
    Do you have a skylight or any kind of south facing window in the loft? If so there's a chance you may be able to install inside (if you search round here a bit
    you can find some links to pages dealing with how to set this up).
    Otherwise, there are alternatives to a normal dish such as those here although how effective these are I don't know (but would like to if anyone does...)
