Wanted: Recommendation for RGB Scart
Discussion in 'Cables & Switches' started by RichA, May 13, 2005.
  1. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
    I have a Sharp LS32GA5E arriving on Saturday, which has the following connections...
    Input 1 SCART (AV input, RGB input, TV output)
    Input 2 SCART (AV input/output, Y/C input, AV Link)
    Input 3 S-VIDEO (Y/C input), AV input
    Input 4 RCA pin (component)
    Input 5 D -sub 15pin, 3.5mm jack (Audio)
    I have been advised to use Input 1 with a decent RGB scart cable for the best result.
    Can you recommend a good value cable that will also give me pretty good pq results?
    Help appreciated.
    Thanks,
    Rich
  2. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Hi Rich,
    What's your budget?
    I would personally recommend the QED SQUART ones, for about £40-£50. IXOS ones also get good raps, I reckon you can get those for about the same price as the QED ones. One things for sure, if the TV comes with scarts already, bin them, anything you buy will be better :)
    Andy
  3. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Nothing will beat the QED P2110 flat scart which sells for 30 quid per metre. Reckoned to be the best scart up to the 60 quid mark.
  4. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Some people use dedicated RGB SCARTS, but I've never had any problem with fully wired (don't have to worry about which way around it connects either).
    However, What I would recommend, should you ever feel the urge to use a SCART switchbox, is to get the flat type. The proximity of the connectors on some of these things make connection the "standard" angled entry type somewhat problematic.
  5. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
