Wanted - R3 Leon.
Kane D Williams
Anyone know a place to import the R3 Leon? It is the DTS version that contains both theatrical and 'International' version I am after. I already own both of the versions on separate releases, but apparently, the AV quality is better on the 'new' (2 disc I think) R3 release?
Thanks for any help.
Will K
It doesn't have DTS, but I got mine from here, if you order 2 titles the P+P stays the same. Very good supplier.
Hope this helps.:smashin:
Sigismund
THX1138 reviewed Leon recently - have a read here. If you definitely want DTS I think you'll have to go for the Superbit version which Phil also reviewed - but I think the R3 version may be the better choice ;)
If you click on the "Compare" tab you can view info. on all the different versions :)
I own the R3 version and I don't think you will be disappointed with picture or sound.........it works for me :D
Sigs
Greg Hook
Moderator & Reviewer
Moved to DVD talk
Greg
